Carburetor problems
Old Nov 28, 2002 | 12:43 PM
mk425's Avatar
Default Carburetor problems
We are having carburetor problems on a Polaris 425 magnum liquid 4 stroke. The problem being that it is flooding I think. If you put a new plug in it, it fires right up and runs good. However, if you let it sit for a few hours or overnight the thing won't start and the plug is covered in gas. I'm thinking that it is the needle and seat not seating correctly. Is that right?? If anybody has any ideas I need to get it back running. Also does anybody have a breakdown of the carb, or know where I can get one? Thanks.
Old Nov 28, 2002 | 02:57 PM
Polaridoo's Avatar
More than likely its the needle and seat. Take the float bowl off and inspect it. Could either be damaged or dirty and not seating right. While you are there check the float height - if it's set too high you can have problems too.
Old Nov 28, 2002 | 07:31 PM
ftwflh's Avatar
THe needle and seat wear out bad on these. When you take your carb off that is a good time to set the valves(i bet that is your probblem)And for a parts diagram go here http://www.partsland.com/
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
kelleycully
Sep 15, 2016 02:57 AM
hondarider1234
Jul 21, 2015 11:53 PM
Shifts
14
Jul 13, 2015 08:41 AM
