Shimming the Primary
Old Nov 30, 2002 | 01:38 AM
dfischer's Avatar
Default Shimming the Primary
HPD suggests shimming the primary clutch when using their next primary springs. This is suggested to bring engage RPM down a few hundred RPM.
Polaris's service manual warns against this in no uncertain terms. Yet, HPD often sells and uses Polaris's pimary springs in the kits.
Has anybody shimmed a primary spring with a washer or two successfully?
Thanks.
dan
Old Nov 30, 2002 | 10:02 AM
Bubba297's Avatar
Dan, never done it personally. I have always liked the higher engagement, so I didnt have a reason to. Look into the plain HPD spring. I had it on my wife's wheeler. It engaged a hair above stock rpms and shifted out great. Also pulled the correct rpms on top (with 53 gram weights). With 55 weights you might get exactly what you want. Just a thought Bubba
Old Dec 1, 2002 | 06:24 PM
dfischer's Avatar
Thanks bubba.
I think I'll put in some silent sport and see if I can quiet it down a bit. I care less about the actual engage rpm then I do the noise.
see ya.
dan
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
