Scrambler 500 Cutting out
Old Dec 13, 2002 | 11:10 AM
  #21
CrispyCritter's Avatar
Default Scrambler 500 Cutting out
Can I get some advice on how to adjust the vales?
thanks
Mark
Old Dec 13, 2002 | 06:36 PM
  #22
ftwflh's Avatar
Pull the gas tank off , take valve cover off ,get motor on compression stroke(where both valves are closed) ,check tappet clearance (it should be .006 on both) Hope this helps Brad
Old Dec 22, 2002 | 08:06 PM
  #23
OK I have checked the Valves and they are good I did as you said. I am still have the same problem. It sounds and smells like the Bike is loading up on fuel and firing on every other stroke when I give i a lot of Gas. If I give it a small amout of gas then slowly add throttle to it, it runs ok but as soon as I let off it will backfire and then I am in the same situation. anyone else have any suggestions?
Thanks
Mark
Old Dec 22, 2002 | 08:41 PM
  #24
ftwflh's Avatar
Hey Mark have you checked the intake boots for cracks it could be sucking air .
Old Dec 23, 2002 | 07:10 AM
  #25
Yes, I took it completly apart yesterday, from the Air box to the Head. recleaned everything that you could image. Everything looks good.
Old Dec 23, 2002 | 09:38 AM
  #26
Bubba297's Avatar
My guess is going to be either CDI box or the coil breaking down after it gets good and warmed up. Looks like everything else has been covered. If it was the carb, it would do it all the time. You know the 4-strokes have a pulse style fuel pump usually mounted up front. On one side of the pump there is a breather hole (looks like a brass mesh screen about half the size of a penny). Other than checking that and making sure it's clear, I would have to stick to electrical in my opinion. These kind of situations get really hard to diagnose sometimes. Hope any of this helps,Bubba
Old Dec 23, 2002 | 12:36 PM
  #27
Bubba,
where is the best place online to get the CDI and Coil. I am looking at partsland but they don't have them listed. just everything else.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Dec 23, 2002 | 12:39 PM
  #28
Duh I found it. [img]i/expressions/face-icon-small-blush.gif[/img]
Old Dec 23, 2002 | 12:44 PM
  #29
jtrundle's Avatar
Did you look your valves over good? I had a similiar problem as you on a Honda 250x. I racked my brain for weeks. Come to find out it was the valves. The edges were rounded off and it was loosing compression. Just a thought.
Old Dec 24, 2002 | 04:41 PM
  #30
swampdonkeykiller's Avatar
Did you try pushing the override switch in when it started bogging and backfiring? Maybe when in neutral, and it starts doing that, push the switch in and see if it revs up fine. It may be a CDI box, but it sounds more like a fuel problem. Maybe your float is sticking a little? Did you try changing the fuel filter?
