K&N Part # for Predator 500
its for the override switch etc electronic throttle control its so when your throttle gets stuck it automaticly shuts off......... also has anyone had problems with start up linking to the override like when you start/choke you should be able to do that without even touching the throttle correct being brand new looking for any help on this one is there an adjustment inside the throttle housing?/
Originally posted by: motoracer51
I removed the stock Predator air filter and brought the thing down to the nearest auto parts store. As I browsed throught the K&N Filter catalog, I happened to match a K&N to the stock filter using their (K&N) dimensions. The part number for anybody interested is 33-2003. It goes on a older Audi. I think it was to a 78-82 Audi 6000 or something. The dimensions matched up perfectly, I just didn't take the time to write down the exact car it is too. To those that have the bike, I've been looking at the airbox/air inlet. It is VERY RESTICTIVE. You have an approx. 2 liter airbox being fed by a 1" diameter intake. Maybee adding some circular filtered vents/and or increasing the airbox intake tube should help. I'll let you know the results.
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
