Does Gas Really Matter
Old Apr 16, 2000 | 01:20 PM
86atc250r's Avatar
Actually, you can use a lower octane at higher altitudes.
Think about it in terms of the pressure in the combustion chamber. At high altitudes, ambient pressure is lower, effectively lowering the engine's compression ratio. There is less air to compress.
One of the reasons they turbocharge high altitude aircraft is to put that air pressure back into the engine, so it can breathe at the high altitudes, otherwise it couldn't generate enough HP to pull itself.
Avgas is a different beast, formulated for specifically for the different demands of an aircraft engine, there are several reasons not to run it in your car or ATV engine, more info can be found by searching Dejanews if you are interested.
Old Apr 16, 2000 | 02:49 PM
MEDSKER's Avatar
Thanks for all the info guys, it is much appreciated.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
stcspiderman
Sep 13, 2015 05:15 PM
awer1968
Sep 8, 2015 11:02 AM
