SP 700 won't idle
Old Feb 16, 2003 | 09:26 PM
scottaboshia's Avatar
Default SP 700 won't idle
It sounds like the pilot jet may be plugged. You have to take the bottom off the carb to get at it but it isn't to bad of a job.
Remove the side pannel on the mag side. Take the carb support bracket off. It has four screws, loosen the clamps on the carb and twist it so you can get at the float bowl. There are four phillips screws on the bowl that have to be removed, then remove the bowl. the pilot jet takes a very small straight screwdriver and is in front of the mainjet.
It should be a #42.5 pilot in it. Either replace it or make sure it is clean. Either way it is a good idea to make sure the carb is clean after it has been under water.
Good luck.
Old Feb 22, 2003 | 12:21 PM
02SP700's Avatar
I performed the throttle ETC adjustment, and that took care of the problem. The ATV is runnung great now.
John
wrencher82
Sep 30, 2015 04:27 AM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
