Bigger carb
Old Feb 18, 2003 | 02:52 PM
JohnnyWyeth's Avatar
Default Bigger carb
Hello all I am looking for a bigger carb for my 96 trailblazer and was told the the mikuni vm34mm will work well. My question is can a vm34mm off of a banshee be rejetted to work on my trailblazer. If not where is a good place to start looking for one that would work. Thanks!!
Old Feb 18, 2003 | 04:15 PM
CED's Avatar
CED
Default Bigger carb
Check e-bay seems like there is always one or two on there.Later.
Old Feb 18, 2003 | 06:34 PM
Bubba297's Avatar
Default Bigger carb
Since the 250 is a piston port motor, I would try to get my hands on a flatslide first. The throttle response would be better. If not then a 34mm is a 34mm. Just have to jet for it.Bubba
Old Feb 18, 2003 | 09:35 PM
mojave300ex's Avatar
Default Bigger carb
I have a 34mm Mikuni carb off a scrambler. I think all of the Mikuni 34mm's would work you would just have to jet them correct. I did all of my mods at once and I didn't really know how big of a difference the carb made till I bolted up my stock just to see and it made a huge difference it will make it rev higher, quicker, and have more bottom-end. You will be very imperssed with the power from a larger carb. I have a AAEN pipe, milled head, bored 0.040 over, ported cylinder. In the 34mm carb I run a 220 main and a 45 pilot it works sweet.
Old Feb 18, 2003 | 09:47 PM
modquad's Avatar
Default Bigger carb
I've got an HPD bored out 34mm carb in the shop. It's now 35.5mm with a UFO installed in the slide. The UFO smoothens out the air, and makes the carb perform like a flatslide. PM me if you're interested. Also have stock airbox (opened up inside) with a K&N/ and outerwear.
Old Feb 18, 2003 | 10:43 PM
2manytoys's Avatar
Default Bigger carb
I used a 34mm off of a Scrammy but the jetting is tricky. You need to use parts from the 30mm and the 34mm to make it work right. It works really well but like bubba said look for a flatside or the one that modquad has works like a flatside. If you need help with the jetting I can tell you exactly what you need to do. Good luck on your search!!
Cole Hadden
Jun 15, 2025 09:05 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
