Enlighten me on Polaris 4wd please...
#41
my 4x4 doesnt work in reverse on my 2000 scrambler 400 4x4. I never noticed it until my last ride. I was on a down hill and had to reverse up the hill. NO 4x4 in reverse, i thought I had lost all 4x4 but when I got turned around 4x4 was working in forward. I also noticed I didnt need to use my reverse override that time either. I'm guessing a have a electrical problem. Any thoughts?
#44
A faulty override button will cause the exact same symptoms. 2 things happen when you select reverse 1) the gray/orange wire is grounded and this cuts the 4x4. 2) when you push the override button, you remove the ground (giving it back 4x4) from the gray/orange wire and ground the purple wire which gives you full power. The problem is in the switch or a broken wire. Trace the 2 wires I mentioned from the handlebars on down and look for damage. I am not sure of the colors or the functions of your model/year because it has changed at least 3 times that I know of, but regardless of color/function changes, the problem lies there. Another thing to check is some models have a plugin connector for the 2 wire to the override switch, if this was partially disconnected and not making contact, you would also have the same symptoms.
