Tiny Tach??
Old Mar 20, 2003 | 02:28 PM
  #31
2minInstigating's Avatar
Default Tiny Tach??
I've got the Cabelas Tiny Tach installed on my Predator, and another one waiting for the Z. It works great near as I can tell. As stated you can't see it very well when ripping along at WOT (hanging on too tight! LOL) and it doesn't respond quickly enough to use when racing. It is great for remembering service intervals, and idle and cruising it works great too. I have seen it reading about 7900 rpm before, and I'm confident it will read higher yet, I just haven't noticed it with the throttle pinned. For 40 bucks I think it is well worth it, unless you really want something for racing/quick response purposes. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 20, 2003 | 11:07 PM
  #32
Rockwalker's Avatar
Default Tiny Tach??
ProX & 2min, thanks for the notes opinions are always welcome, Nice photos ProX very sharp the pure Polaris Tach looks good where you mounted it. 2Min are you running a 2 stroke or 4 stroke and any problems installing etc.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 24, 2003 | 11:05 AM
  #33
Default Tiny Tach??
4-stroke, a predator. Just a side note, this weekend I tried my hardest to read the tach when I was tached out rpm-wise. I am fairly confident that the Tiny tach is not accurate above a certain point, maybe 7000 or so, cause I was revved all the way out in 2nd gear and the tach was reading like 6900 rpm. The funny thing was it read 7600 for about half a second then went back down to 6900, but the engine rpms hadn't changed. I am 99% sure that I am on the rev limiter (have been trying for a while to figure out from people's descriptions what it should feel like) so the tach was reading about 2000 rpms short. By the way, people made it seem like hitting the rev limiter was pretty dramatic, but I wouldn't describe it as "falling on its face". It mostly just stops pulling anymore and stays at one point. Just my 2 cents. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 24, 2003 | 03:23 PM
  #34
Rockwalker's Avatar
Default Tiny Tach??
Thanks for the tip 2min, my main purpose is to just help keep the bike tuned, planning on a Dynojet kit and an AAEN muffler in the future. The tach will make it easier to make these changes.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 24, 2003 | 06:04 PM
  #35
NCScrambler's Avatar
Default Tiny Tach??
If anyone wants a good analog tach. cheap, then get a Sunpro at Auto Zone. It is very simple to hook up and very accurate. It is a little over 2" and Is very easy to hook up. You have to waterproof it where the wires go in, but it is no big deal, just squirt some clear sealant in there and you are good to go. I don't have any pics as of yet, but Bubba297 has the same one on his in his pics. Anyway, just another option.
Old Mar 24, 2003 | 08:08 PM
  #36
ProXPredator's Avatar
Default Tiny Tach??
NCScrambler, how did you hook up a 4 cylinder (4,6,8) tach to a single cylinder bike? Just wondering cause I heard it could be done, but no one at autozone knew how to do it, or even if it could be done.
I've had my Pure Polaris Tach reading 8600 crossing a lake this winter, I know I wasn't at the rev limiter, but you could feel it kick in every time I cought some air and the back end came up! It didn't read fast enough to tell me how high I hit, but seem very accurate to me, if the bike tops at 9000 that is!
Old Mar 24, 2003 | 08:53 PM
  #37
Default Tiny Tach??
Ok I need to say first that this tach WILL ONLY WORK ON A SINGLE CYLINDER 2-CYCLE ENGINE. Ok, set the switch to 4 cylinder. Put black wire to ground, Red wire to the ignition on, White wire to the lights, Green wire to the yellow wire with the red stripe coming from the stator. It is very simple and I have to give credit to Bubba for telling me about this. That is it except for sealing around the openings and the face. It works exceptionally well. As for why it works on the Polaris's since they are just single cylinder, I have no clue.
Old Apr 16, 2006 | 09:39 PM
  #38
garrett5462's Avatar
Default Tiny Tach??
So can you put a tiny tach on a scrambler 500 4 stroke?
Old Apr 16, 2006 | 09:47 PM
  #39
Default Tiny Tach??
and were would u order one cuz at cabelas it is under the boating category, and at tiny tach they have all different models. does the one at cabels work on quads.
Old Apr 16, 2006 | 10:35 PM
  #40
ftwflh's Avatar
Default Tiny Tach??
Yes they will work on a 500 Scrambler and I got one off of ebay but it says Kohler on it but works great.
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
