my polaris went in water over the seat and made it through!!!!did any one go deeper or get stuck because of the belt?
Old Apr 24, 2000 | 01:58 PM
GlennS's Avatar
Maxout's post is an example of someone with no clue about the subject giving there percieved opinion on some they know nothing about. What fixing do you have to do for a wet belt and how can you "water log" a belt?? MAybe it is best you didn't comment at all Maxout!
Glenn.
Old Apr 24, 2000 | 04:47 PM
o2b4unc's Avatar
Maxout.
Good try. No one believes you.
Bye.
Old Apr 25, 2000 | 11:03 PM
mudnsnow's Avatar
Try crossing a silty river and hitting a not seen hole. Your machine (SP 500) will float with you off it. I was able to get it to the bank 200 yards down river and hold it their till my other machine made it across to winch it out. The handle bars were under water for about 5 sec. before she died. Wish I had pictures but the camera drowned as well. I had it going in about 45 minutes. If you think you might get wet use a K@N filter. They dont fall apart after getting wet, and dry out twice as fast. Also carry the red bottles of heat with you. Nothing works faster to get the water out of your fuel system.
I was fortunate to not get water in the oil, but had an extra filter and oil if needed. Polaris needs to add a plug of some kind to the bottom of the belt case. My seat is still a little heavy from the ordeal?
Old May 21, 2000 | 08:53 PM
i4ditch's Avatar
I got water in my case and the belt slipped. The water wasn't very deep but I splashed it pretty good. Are ther snorkels for this problem? Any help is great, thanks.
Old May 21, 2000 | 10:40 PM
  #15
MagnumMudMan's Avatar
I was out riding today and also had the same problem of hitting deep water too fast and getting the belt wet. I have heard of guys using pvc or similar piping to run the snorkel higher. I have also heard this causes overheating problems. I do not know of any commercially made snorkel kit. Ride on.
Old May 21, 2000 | 10:55 PM
  #16
BatMan72556's Avatar
Beat this one!!! I stuck 2 straws up my nose and then tipped my head way back and drove off in the water.The bad part was when a small amount of water made it into one of the straws and almost drowned me.
Wheeeeeeeeeee
BatMan
Old May 21, 2000 | 11:31 PM
  #17
CHICKENman's Avatar
Sounds like your brain got wet also just put it in neutral,And spinn in circles for a few minutes you'll be good as new.LOL good one CM
Old May 21, 2000 | 11:58 PM
  #18
atving's Avatar
I drove my sportsman out in the middle of this deep hole the belt started slipping and it wouldn't move so I left it there for a place for birds to roost, if it had only been green the birds would have loved it more. Apparently Maxout is right, boy wish I had a boat with no suspension that went 25 m.p.h....
Old May 22, 2000 | 12:34 AM
  #19
hoolio's Avatar
I have a 98 explorer and only got water in the tranny once because the vent tube was jerked off. I live on a fairly large creek , and I ride in water daily. My vent tube is just under my seat and never have I got any water in it while it was on, only when it was missing. I have been as deep as the fenderwells and if you stay at a regular pace your fine , However if you let off in that deep of water you will gurgle out. Had that happen a few times. The key is not to panic.
98 explorer soon to have rcr stage one kit.
86 125 Honda wuss mobile
Old May 22, 2000 | 12:40 AM
  #20
425Xpedition's Avatar
My bike will go through water over the seat very easliy. It does not have a belt.
