TIE ROD ENDS ANY THING BETTER OUT THEIR??
99 Scrambler with bad tie rod ends on it! is there any thing better or cheaper then the OEM ones out there.I am playing around with some industrial type rod ends.but i can't find any thing with a good seal on it.
thank you for any help.
2-99 Scrambler 400's 4X4
some hills to steep,some holes to deep!
89 KTM 350 NO HILL TO STEEP!
Hey try have you seen the new tie rod ends that come with plastic boots they are the new himem design and you can fill the rubber boot full of grease I did this and then used water clamps to seal the grease in so far they are working great. Do a search on tie rod ends in the polaris forum they are some guys in here that know where you can get a super dealer on the newer types which they have made them with a grease zerks they really looked good and were pretty cheap too.
Dealer sells them for 19.75 each. Looks allot better than the originals. They started using them on machine made after 8/99 I do believe. You will also need the bolts,nuts and washers. Go to:http://www.polarisindustries.com/pro...p?tips=manuals
Try,
Go here and look at my version of the mods for Tie Rod Ends...
http://photos.yahoo.com/mudmachines_page
Check out the new Mud Pics too...
Get this: My polaris sp500 is almost a year old (almost 6 months out of warranty) and my outer tie rod ends are getting sloppy. I told my polaris service rep about it, and polaris warranted a set of the newer heim style joints--labor and all. I'm going to fill them with grease and hope for the best.
toonces
10-16-2019 12:11 PM
