scrambler tires
Old Apr 2, 2003 | 11:19 PM
NCScrambler's Avatar
Default scrambler tires
I can't find the link I was looking for, but here is what Polaris says about it..so do as you want because I am sure there is a lot of different sides to this and a lot of good arguments both ways. Polaris
Old Apr 3, 2003 | 12:03 AM
hannahj's Avatar
KevinM do you like your 700 alot better than your scrambler im thinking about changing to one could you tell me some of the things you like about it thanks
Old Apr 3, 2003 | 09:16 AM
jamag's Avatar
hey guys, got another tire related question, just got the matching set of front tires and rims for my t.b. 23x7x10 razr's. question what is a good pressure to run them at? im at 5 right now, is that a good p.s.i.?
thanks james
Old Apr 3, 2003 | 10:43 AM
Zak's Avatar
Zak
Kevin,
Do you have an extended swingarm, it appears like you do, if so, how much longer is it than stock, and which brand is it??
Thanks in advance,
"Z"
Old Apr 3, 2003 | 01:17 PM
  #15
KevinM's Avatar
Zak, its a +3.5 and I got it from Dennis Shotwell. Probably one of the better investments I ever made, full throttle holeshots result in the tires only coming up about 6 inches off the ground. If only I could launch the V-Force like I can the Scram. If you want to contact Dennis, I'd recommend going to his forum: Badboyz Polaris
Hannah, the V-Force has suspension, handling and power similar to or better than a Raptor while having the size, auto and comfort of a Scrambler. Unless you have to have the 4x4, you would be much happier with the Kawi instead of the SC500.
Scrambler Pics
fordfaithful21
Dec 7, 2015 05:52 PM
89Lt250r
Sep 7, 2015 07:53 PM
switzomatic
Aug 24, 2015 12:57 PM
mitchxc700
Aug 19, 2015 02:41 AM
maxjung
Jul 13, 2015 05:11 PM
