instead of spacers, has any one reversed the front wheel
Old Apr 3, 2003 | 01:03 PM
jim's Avatar
jim
Default instead of spacers, has any one reversed the front wheel
I was curious if anyone w/ a Scambler/Sport that was going to use spacers, ever just reversed the front wheel instead of using spacers? There is clearance between the valve stem & brake rotor. I wanted to get new wheels w/ an offset to eliminate the 1.5 spacers but I have to go to 2" since they dont used 1/2" increments so that would be the same dimensions as reversing the wheel from 4" x 2" to 2" x 4" offset. That should make the front end about 49" wide.
Thanks
Jim Maloney 98 400 scrambler
http://photos.yahoo.com/jim400scram
Old Apr 3, 2003 | 01:08 PM
KevinM's Avatar
Jim, I reversed mine when I first got it. The valve stems will rub, so all you have to do is face them downwards and drill new holes for the new valve stems. It really helped the stability, but it was too wide for harescramble riding in my opinion, but if you ride mainly in sand you would probably like it.
Scrambler Pics
Reactant
Mar 30, 2022 02:08 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
JackTheKing
Jul 14, 2015 09:09 PM
Scottma518
Jul 10, 2015 12:42 AM
jettman
Jul 6, 2015 12:16 PM
