Question For Scrambler/Trail Blazer 400 Owners - BLOWN - NO COMPRESSION!!
Old Apr 4, 2003 | 01:35 AM
dailyrider's Avatar
Default Question For Scrambler/Trail Blazer 400 Owners
[img]i/expressions/face-icon-small-smile.gif[/img]Something to check That I have found on way to many polaris' is the nut behind the stater coming loose. This will alow the gear to slap back and forth on the keyway. Making a knocking noise. Just somthing to check.
Old Apr 4, 2003 | 02:17 PM
scramblered's Avatar
HOW MANY HOURS???
i'used to have this kit in the past,full race hot seat exterminator,be careful to check engine compression after each run...
with the 42mm carb,it is just unreliable.
Old Apr 4, 2003 | 03:11 PM
ScramblerX's Avatar
They all rattle, make sure your not lean, and don't worry about. It is normal on the 400's.
Old Apr 4, 2003 | 10:45 PM
GregV's Avatar
Here is another question: How do you guys do a plug check on your automatics? On my Raptor I would just do a high RPM run in 3rd. gear then pull the clutch and hit the kill switch, coast to a stop and check it. I know that the clutching on it is so aggressive that it is dissengaged for the most part when you let off the throttle.
What do you guys do?
Old Apr 4, 2003 | 10:56 PM
  #15
NCScrambler's Avatar
Just reach over and hit the kill switch while you are at the throttle range you want to check, after about a 1/4 mile of course.
Old Apr 4, 2003 | 11:00 PM
  #16
GregV's Avatar
Do the same rules appy on a 2-stroke as it does on a 4-stroke?? Look at the base ring??
Old Apr 4, 2003 | 11:07 PM
  #17
Yeh I think so, pretty much same. This link right here 2 Strokes can answer about any question you would ever have about 2 strokes.
Old Apr 5, 2003 | 12:11 AM
  #18
GregV's Avatar
Thanks NCScrambler.........that looks like some good stuff! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 13, 2003 | 11:29 PM
  #19
RhondaV's Avatar
Well, I think Greg's suspicion was right. Something was wrong with my quad. I took it to the dunes this weekend and it died on me. I barely made it through the gate. It lost all compression. We changed the spark plug, sprayed starter fluid in it and nothing helped. The weather was around 50 and I don't think the oil was getting pumped because it had not went down at all and I have ran 3 tanks of gas through it before this happened. No resistance at all on the pull cord.
Old Apr 13, 2003 | 11:54 PM
  #20
GregV's Avatar
Default Question For Scrambler/Trail Blazer 400 Owners - BLOWN - NO COMPRESSION!!
well, I guess it's time for higher compression and an oil injection block off!! [img]i/expressions/face-icon-small-disgusted.gif[/img]
