Bleeding the oil pump
Old Apr 14, 2003 | 06:09 PM
NCScrambler's Avatar
Default Bleeding the oil pump
HPD sells that cable for $24.95. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 14, 2003 | 07:17 PM
duneaholic's Avatar
Thanks NC.
Old Apr 14, 2003 | 07:21 PM
No problem. I have been looking at the same thing and that is the best price I have found, so I thought I would pass it along.
Old Apr 14, 2003 | 09:07 PM
duneaholic's Avatar
Just ordered the block off kit and cable from HPD. Peace of mind.
Old Apr 26, 2003 | 11:25 AM
  #15
paulywally's Avatar
Start at the oil tank by removing the oil fiter that is behind the white clutch air tube on the left side and make sure oil is flowing from the tank. If not take it off and clean it.
Replace the oil filter with a new one.
Take the oil line off the oil pump and make sure it is coming through the pump.
If not replace the oil pump.
You will need a service manual to instruct you as to how to adjust the oil pump advance. it is controled with the throttle cable.
Old Apr 26, 2003 | 11:35 AM
  #16
modquad's Avatar
Good info Pauly, but I guess he's going the removal route.
Old Apr 27, 2003 | 10:37 AM
  #17
Bertman's Avatar
what pre-mix ratio are you guys running? 20:1, 32:1,40:1.50:1
Old Apr 27, 2003 | 01:21 PM
  #18
40:1 here.
Old Apr 27, 2003 | 07:30 PM
  #19
Farmr123's Avatar
You can also add a petcock to the oil tank, and use it as an extra reserve fuel supply, if you block off the pump.
Farmr
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
rockinkgin
Sep 25, 2015 01:52 PM
Sw00p
Sep 24, 2015 02:50 PM
