sprocket help asap please
Old Apr 15, 2003 | 08:54 PM
colopred's Avatar
Default sprocket help asap please
Can anyone help me? - have my predator stock sprocket off but cant get it around the hub to get it off - do i need to remove the hub and if so how. I'm trying to put on a 39 tooth sprocket right in the middle of project and kinda stuck. Help please.
Thanks,
Jeff
Old Apr 15, 2003 | 09:01 PM
NCScrambler's Avatar
On my Scrambler you had to remove the hub, so I would guess you would have to do the same for the Pred. All I had was a big cotter key and a big nut, Pred is probably different though.
Old Apr 15, 2003 | 09:04 PM
Well, went and looked and to my suprise it is the same. Look here. Hope this helps.
Old Apr 15, 2003 | 09:48 PM
colopred's Avatar
Great thanks - I went back out right after I posted that help message and gave it one more try , with a little tap in came off without me having to remove the hub and the new one went on even easier (without hub removal) I cant wait to try it out but its windy as hell and raining here now. This sprocket looks sweet - its black and very very light compared to stock but is suposed to be stronger. I got it from esuperbikeshop.com - they make 39 and 40 tooth for pred. Anyways im very happy with the quality - it fits great - does not rub on the rear sprocket protector and looks great. Hoping it helps out my low end over stock.
Thanks again,
Jeff
03 PRED
W/B slip on
39 tooth rear sprocket(black)
PRM radiator scoops
shock covers (black)
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
slowgsxr97
Sep 8, 2015 07:33 PM
400H0
10
Aug 20, 2015 07:34 PM
