Rejet?
Old Apr 18, 2003 | 01:18 PM
SuzukiQuadrunner160F's Avatar
Default Rejet?
can anyone help me with getting the carb off?
Old Apr 18, 2003 | 03:28 PM
NCScrambler's Avatar
Default Rejet?
If nothing happened, you should be ok. If it got better slightly, then you need to raise the main jet. If nothing at all happened, then you should be ok. The choke will richen the carb and if you are lean it gets better and if you are rich gets worse, so if nothing happened, then I would say you are ideal, but if you want to be on the safe side, you could go up with the main and it wouldn't hurt anything as you added gas with the choke and nothing happened, so.... I cannot help you with the carb, I am not familiar with the magnum. Maybe ftwflh can help.
Old Apr 18, 2003 | 06:58 PM
ftwflh's Avatar
Default Rejet?
Read my previous post.It is a major pain.
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
cSchwartz
Jul 9, 2015 02:43 PM
Bm400ex
Jun 22, 2015 09:16 AM
quad_300ex
Jan 23, 2000 10:17 PM
