Major trouble with Hpd Scrambler!
Old 04-24-2003, 04:22 PM
NCScrambler's Avatar
Default Major trouble with Hpd Scrambler!
True Modquad, they need time, sorry for being so impatient in times like they are having. LOL
Old 04-24-2003, 07:22 PM
abaran's Avatar
Thanks for the reply's guys. I did re-torque all of the nuts before I ran it the second (final) time. I mixed oil with the gas, but only 1 of the 4 or so gallons in the tank. So I didn't add a whole lot of oil to the tank. As far as jetting, I know nothing about it. The guy from Hpd said it would be all set when he sent it back to me. In fact, I called him today and told him what happened and he thinks there wasn't enough oil with the gas. He mentioned that I should have adjusted the oil-injection pump. I may put in the oil-injection block-off since I am going to probably need another new piston.
If the oil mixture isn't right, can that cause this to happen?
I'm not real experienced with this type of stuff yet, so I guess I'm learning the hard way!
Thanks again,
Colin
Old 04-24-2003, 09:23 PM
Pennyless's Avatar
The oil mixture needs to be right. I have two Aaen ported 440s and I run 32 to 1 mix. I melted two pistons before I blocked off the oil injection. I have had no problem since then.
Old 04-24-2003, 09:29 PM
Yep not enough oil can melt a piston quick, since you are pretty big on mods and putting that much more gas into the motor, you should probably do a block off because the oil pump may not have enough oil to give to that extra gas.
  #15
Old 04-25-2003, 09:42 AM
scramblered's Avatar
abaran,i run mine at 50:1 with klotz all year round,it is 13 once of oil for 5 gallons of gas.
but still 1 gallon of oil along the pump shouln't be that bad,check your jetting for sure,it is with the spark plug.
95wolv
09-27-2024 12:00 PM
exmotocrosser
09-13-2019 06:12 AM
mrtidy
02-03-2016 05:00 PM
Matt123
09-29-2015 01:29 AM
Clint Russell
09-25-2015 03:20 PM
Quick Reply: Major trouble with Hpd Scrambler!
