Warn 3.0ci and Sp700
Old May 4, 2003 | 03:41 PM
SpruceDuece's Avatar
Default Warn 3.0ci and Sp700
Does anyone have a part number or supplier for a mounting plate for the Warn 3.0ci to go onto my 2002 SP700??
Thanks,
SpruceDeuce
Old May 4, 2003 | 05:29 PM
V8s10's Avatar
Do you want to mount it in the hole in the front bumper?
Old May 4, 2003 | 09:26 PM
V8S10-
I would like to mount it in the stock spot above the bumper. I have the dual tube bumper installed. I had thought about a multi-mount, but would have to get a new bumper or go without.
Thanks-
SpruceDeuce
Old May 4, 2003 | 10:10 PM
V8s10's Avatar
I mounted mine in the bumper but I built my own mounting plate. The 2.5 mounting plate is designed to position the winch vertically and the plate goes behind the bumper. There are 2 slots in the bumper located towards the left side. The 3.0 mounting pattern is in the center of the winch, also it is slightly larger than the 2.5. I was unable to get the 3.0 all the way inside the hole, I mounted it horizontally and used the brushguard to support the front part of the mounting plate. I would contact Warn and see if there is a plate available for the 3.0. There was a post on here a while back about this same subject, you might try searching for it. I think the guy had a part number, I can't remember his name.
Jeff Roper
Feb 1, 2022 11:48 AM
toonces
Oct 19, 2015 02:21 AM
panicmanic
Sep 28, 2015 12:59 PM
Erick J. Edler
Sep 20, 2015 05:51 PM
Gtsordo
Jul 22, 2015 01:27 PM
