tune rear brake in scrambler 400 4x4
Old May 8, 2003 | 08:14 AM
chipopo's Avatar
Default tune rear brake in scrambler 400 4x4
hello
i have a problem whan i push the rear brake it just dont stop its like the pad dont push enough on the drum
i need to tune it can some one explain how to tune it??
thx
Old May 8, 2003 | 08:18 AM
Predator03's Avatar
Your problem is most likely air in the brake system. I had the same problem with my Scrambler. The air needs to be bled out of it. The only thing that I found to work, was using a MightyVac. You attach it to the bleeder screw and it draws the air out of the system. That auxilary brake isn't the greatest thing anyways. You can find MightyVac's online. I never could get the air out any other way.
Scott
Old May 8, 2003 | 08:24 AM
chipopo's Avatar
hi
i dont think that the rear brakes works with brakes oil so it cant be air in the system
and also i can see that the pad dont press hard enough on the drum its looks liks its just need some tune
Old May 8, 2003 | 06:28 PM
chipopo's Avatar
where do you fill breaks oil in the scrambler and what kind of oil?
Old May 8, 2003 | 06:54 PM
BigBadScrambler's Avatar
The rear brakes have brake fluid in them too. The scram takes DOT 3 brake fluid for the front and rear resivior. The main resivior is on the left side of the handlebar. The rear resivior is on the right side near the floorboard next to the tranny.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
DeFox500
Jul 26, 2015 06:32 PM
maxjung
Jul 13, 2015 05:11 PM
