Please help with chain tightening
NCScramble & pudijumpr, I'm glad you guys are out there - always like to here from you guys. Good advice on the chain. I would just add that it's easy to over tighten the bolts at the brake calliper as it is aluminum. I would use a mild lock tight if I was worried or just don't kill the bolts going back in and tighter is OK on the axle. Again I see your names and READ. Modquad, 2manytoys and the Farmers are good too, just to name a few!
mrtidy
02-03-2016 05:00 PM
