Scrambler 500 Carb jets
I ordered the HPD powermaxcx exhaust and have almost got the quad torn apart. Can someone send me a scanned pic of a manual for hte carb on the thing? In the tight jumble of hoses and such, I want to make sure I am opening it up correctly without making a nightmare for myself.
I especially need to see where the jet location is and the idle and mixture screws, if any.
Thanks guys!
usmcquader@comcast.net
Thanks guys!
It is the #32 like NC stated. I believe it is a flat head. I definately know that it is not a allen head. You may have to drill out a brass plug though, although mine was already drilled out. The main jet is under the drain plug. Once you get is all back together, it may take some starting fluid to get her to fire up. I know it did for me. If you run into any more troubles just ask. I went through all this last year.
1000gade
07-16-2015 10:48 AM
2003, 500, ascrambler, carb, carburetor, information, jet, jets, located, location, pilot, polaris, scrambler, scramblers, settings
