Could Someone be of Assistance Please
Old May 11, 2003 | 08:59 PM
Alpine2's Avatar
Default Could Someone be of Assistance Please
I was out today dirving around came to a washout put it in AWD and when I hit the gas I hear a snap sound comeing from the the right front it seems to be coming from the CV joint I was wondering do you all think that is the problem I would just like a second opinion before I order one in.
One more thing I see epi sells just the CV Joint Kit Includes: CV Joint, Boot, Clamps & Grease for $139 or the whole thing shaft and all for $239 I was thiking just the CV joint itself save money ,Has anyone done this how hard is it does not look to be to diffucult I am pretty mechanically inclined and figure while I was doing it to also put in some adjusters for the front springs for adjusting preload and get rid of the sag
I thank you for your input
Old May 11, 2003 | 09:01 PM
kblazk's Avatar
is the shaft broke in two pieces? take it to your dealer before you replace something that aint broke
Old May 11, 2003 | 11:00 PM
ftwflh's Avatar
First take your hub off and see if something broke in it.It could be a bearing bad,hilard clutch broke,or just low on fluid.If nothing is bad in there then go to the CV joint.Be sure all the grease points are greased too.
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
David Diaz
Sep 8, 2015 04:44 PM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
