Lift ?
Old May 12, 2003 | 11:13 PM
upnort's Avatar
Default Lift ?
I just got some 27" mudlites on C-series. I added a 1" highlifter wheel spacer on front after found out that tires hit tie rods. Now it will run but tires rub when turning sorta sharp. Don't really want to put in a whole lift kit because for "smooth non mud" trails would like to switch back to regular wheels. This is more for mud setup. Heard about stronger springs but even with no weight on atv seems close. Rears are fine. Any ideas to HELP???
Thanks
Old May 15, 2003 | 02:23 AM
PRAIRIETWIN's Avatar
Default Lift ?
Put 1" spacer in strut housing under strut for lift. Or cut fenders. You can use washers for spacers.
Make a bracket for rear shock to lift rear. Two straps and a small plate welded to straps. Drill holes and place on swing arm and shock, just another spacer between swing arm and shock. Simple!
QuadRiders
Oct 22, 2015 04:13 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
