Wheel Spacers - Anybody Using Them?
Old May 13, 2003 | 05:00 PM
duneaholic's Avatar
Default Wheel Spacers - Anybody Using Them?
I have the 2.5" on the back and love'em. Along with the Razrs it turns like a dream. They work well in the sand also. Don't get any big air with wheel spacers or you just might bend an axle.
Old May 14, 2003 | 12:29 PM
jim's Avatar
jim
Thanks Dodgepower, I made the pegs w/ extentions myself. I used white RTV for the plastic holes for a while & then I think I took it out for the pictures. I had PEP do a custom rebuild of my rear shock to tripple valving exactly to my weight, the machines new weight & the type of riding I'm doing. It was another HUGE improvement. At high speed w/ stock rear suspension, the rear end wants to swap & bounce around back there (very dangerous) because the rear shock re-bound is very slow stock & start to stackup but after the re-build it rebounds like the pro quads, very fast & very contollable. I use the Works front stuts which are air adjustable so if I'm jumping a lot I pump it up to 55psi & if I'm just trail riding I use 30psi. Believe me, this is a VERY plush ride on pot holes, hitting boulders at speed etc compared to stock. It was another big improvement.
Duneaholic, I may be just lucky but have not bent anything yet & I jump all the time. I did go to the heavyduty front springs w/ the Works stuts pumped to 55psi to resist bottoming on the big jumps. Total for front & rear was about $500 which is REALLY cheap concidering what your getting & compared to my friends 250R's suspension costs. Hope this helps.
Jim
Old May 14, 2003 | 01:20 PM
axisII's Avatar
I reversed the rims on the front and back of a warrior and it is much more stable, but beware....last weekend i was riding and the front left tire caught a stump, ripped the handlebars out of my hands and broke my index finger pretty bad. With a wider front end its a lot harder to hang on to the bars if your front tire ever hits anything.
Old May 14, 2003 | 02:08 PM
jim's Avatar
jim
I mentioned earlier about the need to use a steering stabilizer when you widen the front end & I tried both the HPD 7 posistion adjustable & the Aaen 7 position adjustable & by far the Aaen was far superior. You could adjust the HPD up & it barely made any differenece whereas the Aaen, if you adjusted it up, it was almost too much cuase it slowed your steering up. The Aaen was much more effective.
jim
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
