Noob help 400HO not starting
Hi everyone,
Apologies for the naive questions/statements but this is my quad and now attempt at fixing something like this.
I have a 2013 400HO with only 200km on it.
It has run fine for the last month that I've owned it without any problems at all.
Yesterday, it has trouble starting in that when I turned the key it took quite a few tries to get the engine to turn over and start. I used the choke full and then halfway and it started. It is still cold where I am (Northern Alberta) so I figured it had to do with the cold weather.
Today, I was an hour deep in the bush and when trying to start my quad it just wouldn't turn over. I tried the choke still nothing. At one point a small puff of smoke came up from the main area under the headlight.
I was able to get my buddy to tow me back to town so my winch worked so I dont think its the battery (have it on a trickle charger now to rule that out).
Could that smoke be from a fuse? solenoid? spark plug?
Sorry for the noob question and greatly appreciate all your help! I am stuck in the bush for another few weeks until the peace river breaks up and we can get back across so hoping to do repairs my(inexperienced)self until I could get it out to a proper mechanic.
Cheers guys
Cheers guys
Think I'd check where that puff of smoke came from. Probably the Delphi fuse block as they were bad about pins corroding and wires shorting against one another. Take the block up and look underneath. If you need a new one they are cheap on ebay.PER-080&029&036-4 ATO / ATC Delphi Fuse Block Panel 4 Gang 12 V Blade Style Fuse | eBay or you could find a better water resistant block.Not a bad idea to check that it's charging ok(once you get it running) and load test the battery also. If it drops lower than 9.5-10 volts under a starting load,time to replace it.
One you get the plug out,lay the plug against the cylinder and check for spark. If you don't have spark,you need the trouble shooting guides from the manual and ignition tests.https://www.tradebit.com/filedetail....500-forest-atv
Thank you! If I get no spark I'll try the spare spark plug I have and let you know. Thanks so much for walking me through all this!
FOund this broken wire: https://postimg.org/image/tzeoir59z/
also Just came across this post, any idea how I would get that fuse out to check? No Spark,but cranks.2012 400 sportsman Carb - Polaris ATV Forum
