New here and need help with ToaToa 110b
Old 10-08-2017, 01:33 PM
Jennnifer.b's Avatar
Default New here and need help with ToaToa 110b
Ok I have about had it with this 110 tao tao 4 wheeler. I have replaced everything on the thing. I have spark. I have spark under compression. It fired up the other night once then I couldn't get it to fire anymore. It cranks and cranks and will not start. I have gas going to the carb. I'm at a loss I have no idea what else it could be.
Old 10-09-2017, 10:42 AM
Hi Jennnifer. I'm moving this to the Chinese section. Might get more of a response there.
-Administrator
Old 10-09-2017, 11:21 AM
DirtDevil101's Avatar
Does it run with starting fluid sprayed directly into the plug hole?
Old 10-14-2017, 09:39 PM
Start up the other day. But it's very hard to get started. Lots of cranking and playing with the coke and giving it gas. I moved the flot but it didn't help. Once it starts it runs good. But just getting the thing to start is the hard part.
Old 10-16-2017, 09:38 AM
Again...did you try starting it by spraying starter fluid directly into the plug hole? If it fires right up doing that it eliminates many other variables...
Also...you state "spark under compression"...do you know your compression number (crank with throttle wide open)?
Old 10-17-2017, 09:27 PM
no I don't know the compression number. But I have noticed that it fires up easier when I have my tester on it. Testing the spark I'm guessing it's because it has more resistance making a hotter spark. I try starter fluid in the plug hole once but at that I'm I don't think I had spark. I replaced wiring harness and cleaned the flywheel and stator and got back spark. All the problems came along after my daughter ran it through water. It was never hard to start be4 that.
Old 10-18-2017, 10:05 AM
Sometime things are coincidental...
I'd also look at your ground and ensure it's secure to bare metal.
Hard starting can be weak spark, but it can also be low compression and/or insufficient fuel (all a choke does is richen the fuel mixture to help on cold starts)...
grumpyjarhead
07-22-2016 01:55 AM
Kanderson7271@gmail.com
04-26-2016 08:58 AM
VRRRRT
06-27-2015 09:38 AM
DFW Rusty
14
12-28-2013 05:52 AM
Timpemberton
15
06-13-2011 03:03 PM
Quick Reply: New here and need help with ToaToa 110b
