Wanting to swap motors on 110cc quad
I am have motor problems on my 110cc chinese quad so i figured now is the time to upgrade.
I want to put this motor on it and was seeing if you guys think it will fit.
A Engine Assembly - 125cc 4-stroke ATV Engine Semi-Auto Transmission w/Reverse, Electric Start for most China made 125cc ATVs & upgrading 50cc-110cc ATVs
It says it will fit on 110cc quads but i have a concerns.
My current quad does not have a clutch. So can i still make it work?
Also any ideas about it or suggestions on motors for it.
It says "semi auto" in the blurb, so I would guess the clutch is worked by the gearchange pedal/lever on the replacement engine. I can't see there being a big difference in power between a 110 and a 125 though. It is intended for bikes with engines that look like that, i.e. Honda Cub clones, if your engine is different, vertical cylinder for example, it probably won't fit, and they do vary in where the starter motor goes. So, if yours has starter under engine, will a top mounted starter foul on frame, exhaust, or carb?
dbusch22
10-26-2021 03:51 AM
tbyrd
01-09-2001 09:13 AM
