Ds650 baja starting problems
Old 06-25-2018, 07:35 AM
Stump1013's Avatar
Default Ds650 baja starting problems
Ok guys needs some help asap ready to set this thing on fire..thing would never start valves were tight i adjusted the calves to correct shims on intake n exhaust have plenty of clearance in between cam lobes n shims..problem is i done set tdc about 10 times now its dead on..will not fire one hiccup sprayed gas into carb while cranking n while not all it does is make a loud backfire n some flames come out. Its like valves are tight but there not.idk how it could be firing wrong with it at tdc. I need help asap carn is clean have plenty of spark bright blue.
Old 06-25-2018, 08:36 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Sounds like timing is still wrong. Check the flywheel keyway to see if it sheered.
Old 06-25-2018, 09:28 AM
Stump1013's Avatar
I checked that its not sheared.
Old 07-13-2018, 08:32 PM
MRDS650's Avatar
Canadian and Proud of it !!!
Did you pull off the flywheel - its sometimes hard the see. I thought the same on mine, until i pulled the flywheel. it sheared it and only moved an inch or so but thats enough to make it backfire and not start.
Old 07-13-2018, 09:07 PM
Stump1013's Avatar
Yea i pulled flywheel off.even if it was sheared i would be able to hear the flywheel spinning
Stump1013
06-25-2018 07:43 PM
Stump1013
CAN-AM (BRP) Ask an Expert!
16
06-24-2018 09:08 PM
bird720
02-16-2013 10:23 AM
MotoXtreme
01-18-2004 07:00 PM
Quick Reply: Ds650 baja starting problems
