Taotao 110cc atv cranks but wont fire
Old 08-25-2022, 01:17 PM
Mbrooke33091's Avatar
Default Taotao 110cc atv cranks but wont fire
I have a taotao 110cc atv that back fired a while back and hasnt started since. It turns over but wont fire. Ive changed the spark plug, carb, battery, gas and oil, ignition switch and swapped the cdi. It has spark, gas and compression. I cant find anything visibly wrong with the motor. Im thinking of removing the motor but before I go that far I want to make sure Ive checked everything else!
Old 08-26-2022, 01:45 AM
Very rare that you need to remove the engine to fix a problem. If you have a good spark and compression, with a new carb, it should at least fire, if fuel is getting to carb. I would check for ignition timing slipping. Is the TDC mark on the flywheel at TDC by the piston? If that is correct I would then check if valve timing has slipped, so do the timing marks on flywheel and camshaft sprockets agree? Note they will only agree once every two revs.
KatieG
08-21-2021 02:07 AM
Justmile1979
04-19-2021 09:39 PM
moparman06
03-02-2021 10:33 AM
x1cd
12-30-2012 06:33 PM
Quick Reply: Taotao 110cc atv cranks but wont fire
