Sport Quads Discussions on sport quads.
how fast is this shee
Old Jun 18, 2004 | 09:53 AM
Bubba297's Avatar
Default how fast is this shee
My Banshee at the dragstrip with a 16-41 pulled just over 93mph and it was topped out in 6th gear. I am far from a stock motor with in-frame drag pipes, larger carbs, 18cc heads, and porting. A calibrated radar gun or dragstrip type timer is the only good source for correct speed readings.
Old Jun 18, 2004 | 11:21 AM
AlkyBurninX's Avatar
Originally posted by: YamahaRiderOnly
lol No, How dont you think it will do in the 90's ? I think it shouldnt have any problem at all.
I don't mean to sound like a jerk here but, how many banshees do you own? I only list 3 of mine in my signature. How many banshees have you built? I currently have 2 stroker motors and one ported 350. How many banshees do you race? I have one for flattrack/TT, a drag bike that will be finished next week, and an MX bike.
With 15/41 gearing, at 10,000rpms in 6th gear a banshee will do 86mph. Good luck spinning a stock motor to 10,000 in 6th. Most built banshees make peak power at 95-9700 and fall off quickly after that. It hard to get even a built one much over 10 grand under heavy load.
Old Jun 18, 2004 | 11:22 PM
YamahaRiderOnly's Avatar
Our Cop Friend must have a $hitty Radar Gun or something because my Banshee did around 81 to 83 mph with a 15/41 gearing and it is totally stock. I think that it should be able to do in the 90s with his setup and different gearing, How fast were your banshees when they were Stock? Just wondering
Old Jun 19, 2004 | 11:25 AM
I never have put a radar gun on any of my bikes. If you take the rpm's of the motor and figure in transmission ratio and then add in the final drive ratio as well as the tire size, that will give you a top speed. I use an excel spreadsheet to figure this. This number is consistant. It has nothing to do with wind or any other factor because if you are going against the wind, your motor can't rev as high. My TT bike with 16/39 gearing will turn 82 MPH in 5th at 10,000. I think it is only like 92-93 in 6th.
Old Jun 20, 2004 | 10:16 AM
  #15
Tecate4Fun's Avatar
Mines faster.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 20, 2004 | 02:07 PM
  #16
xraptor660rRider's Avatar
how much hp u think its got
Old Jun 22, 2004 | 08:40 PM
  #17
QuadLT500Racer's Avatar
its only bolt on stuff, so im guessing it has 50hp MAYBE more from all the sources ive seen through the years. i rode one with basically the same mods and doubt it will do much over 80
Old Jun 22, 2004 | 10:49 PM
  #18
iceman32crx's Avatar
when you do the spreadsheet do you figure parasitic loss (loss from machines not being 100% perfect) every connection from the motor down to the ground loses a little bit of power dont know how much it would be for a atv though!!!
Old Jun 22, 2004 | 11:53 PM
  #19
Iceman, exactly I am saying in the "perfect world" with no loss it would only be 86mph. If you figure in loss it would be even less.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Irishman301
Sep 23, 2015 01:47 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
