brakes
i think my back rotor is bad i check my brake pads like 2 months ago and they were fine and i have a couple small dents in the rotor and i think its bent a lil and rubed the pads and wore them out and my rotor had sum metal scraches around it where the pad rubs...do i deff need a new rotor and if i jus put new pads will it wear them down really fast and is it hard to take the a rotor off a raptor
You should change the rotor while you do it, it's pretty easy. A bent and roughed up rotor will just eat your new pads anyway. It would be even better if you don't already have a wave or self cleaning rotor. I saw srp metals makes these rotors for $70 at magicracing.com, but I haven't tried them out yet. I will definately have a new one installed on the rear of my warrior before the spring.
oliveiracarlos
Sep 7, 2015 03:39 AM
