air filter care
Matters what kind of air filter your talking, K&N or a foam filter? If K&N i use a K&N treatment and oil spary, foam i would use the PJ1 foam filter cleaner then the PJ1 foam filter treatment (super tacky)
Spray on PJ1 cleaner (from inside out if you can) and let is sit a few minutes. Thoroughly rinse FROM THE INSIDE OUT with warm water. Dry completely! Saturate with Maxima FFT then squeeze out excess.
I use to use Maxima FAB spray, but I found that it doesn't penetrate into the filter unless you use tons of it, and that gets $$$$. FFT is the same stuff, just not in a spray can!
Customer Service #1
May 15, 2020 08:46 AM
Steeldon
Sep 9, 2015 09:38 AM
