Sport Quads Discussions on sport quads.
Need Help
Old Sep 14, 2016 | 10:34 AM
Polaris03's Avatar
Default Need Help
I have a 03 Predator 500 that wono start without giving it some throttle, and wont stay running unless i give it throttle. Need Help!!
Old Sep 17, 2016 | 10:13 PM
Suzukirob's Avatar
does turning the idle adjustment screw help any? If not, i am leaning to a good carb cleaning will need to be done. how old is the gas in it?
Old Sep 17, 2016 | 10:22 PM
Polaris03's Avatar
Default Thank you
Completely crossed my mind thank you. It ended up being the idle adjustment
Old Sep 26, 2016 | 03:56 AM
kaufm1978@gmail.com's Avatar
The idle air jet is plugged. If you clean your carb and make sure you can see light through the jet. Take a blow gun and blow out all holes in bowl area. Spraying it with carb and choke cleaner. But most of all just make sure it's clean before you put the bowl back together. Hopefully this will help you out.
higgs
Oct 10, 2016 08:34 PM
Marjorie
1) Engine problems..
Sep 20, 2016 04:16 PM
Cameront23
Sep 13, 2016 01:23 PM
Cameront23
Sep 12, 2016 09:26 PM
