Sport Quads Discussions on sport quads.
chain question(s)
Old May 14, 2002 | 04:39 PM
bbertram's Avatar
I just bought the Z400 and I'm curious, how durable are the chains on sport quads? Do they need replacing every year? How much maintenance do you need to give to the chain? Do they come off allot? I have never owned anything chain driven so I don't know this stuff.
Old May 14, 2002 | 04:44 PM
THEMOOSE's Avatar
It mostly depends on how much & how hard you ride & how you maintain your quad.
The chain is very tough, Keep it lubed, clean & properly adjusted & it'll last a longer time.
When you do replace your chain replace both sprockets at the same time. You'll destroy a new chain in no time with worn sprockets!
Old May 14, 2002 | 05:23 PM
CBUS660R's Avatar
Make sure that you use chain lube. WD40 or motor oil will break down the rubber o-rings in the chain and ruin it. Also, when you clean it, don't use a wire brush or anything abrassive that can damage the o-rings.
Old May 14, 2002 | 05:28 PM
bbertram's Avatar
To clean it I was just thinking about using the garden hose or do I have to clean it better than what the garden hose can do?
Old May 14, 2002 | 05:55 PM
CBUS660R's Avatar
That'll be ok. Maybe hit it with a soapy spounge or towel also. You're really just trying to get the heavy debris off, nothing more. Once you are done washing it, ride around a little to get the chain warmed up before you lube it.
Old May 14, 2002 | 06:01 PM
bbertram's Avatar
Thanks for the info. I'll probably have many more questions once I get my quad next week.
Old May 14, 2002 | 06:36 PM
EeEcksRider's Avatar
don't lube your chain right after you wash it, you will trap water particles inside the little nooks. bad.
yes, a chain is best lubed warm, but let the chain dry 100% first.
Firefighter400
Oct 8, 2022 06:38 PM
frostphase
Aug 23, 2015 07:36 PM
Anomers
Aug 16, 2015 11:06 AM
DeFox500
Aug 14, 2015 05:59 PM
95wolv
Jul 17, 2015 08:13 PM
