400ex vs. warrior
#41
I have a 2001 warrior that has the mods done to it and I am working raptors. For the same price as a Raptor I can build a big bore for it. And as it is I have no problems keeping up with 400ex. you can get a used one for aroud $3000, put a pipe and jet kit, prodesign Air intake, high compression piston, Keihin carb, and anything else you can think of and still only be in it under $5000, which is still less than a raptor or 400ex. FYI they can ride wheelies and do stopies, they do great in the dunes and un the mud (with the right tires).
#44
Not flaming here, just stating my .02 cents..
But with just shocks you will have no where near the suspension that a 400ex has! I have a 250X with ext a-arms and works shocks and I dont even come close... I feel that Warriors are more of a sport utility quad rather than a true sprot quad or high performance quad. No offense. The suspension and weight just cant compare with the others. Plus with 350cc I feel they should have a little more power, but I the feel more like a 250x range power....(stock wise)
#45
That is what I am saying, for the same amount that you would spend on a new 400ex you can build a warrior that will far surpass the performance of a 400ex. And it will still cost you less in the long run. I know, I have one. I have no problems racing with the "Big Boys", raptoprs, 400ex, and cannondales, If you put a couple grand into a warrior you will still be in it less than a new 400ex. You can build a 420cc stoker for it, change the sprockets, extend the rear axle and swing arm, and replace the a-arms with +2 or +4's for just a couple grand. Which if the bike was used, is a whole lot less than a 400ex with all the mods.
#46
Ive got about 800 dollars in my engine and we will soon see but im pretty sure I can toast a 400ex and if not beat a z400 hang right there with it. So including engine work how much have I spent total on my warrior? 2100 including inital purchase. No 300ex is going to beat me unless it has a 395 kit and is very" tweaked"
#48
There is usually less than 800.00 difference between a used Warrior and a used 400ex in my area. You would have to do major engine work to run with a stock 400ex and it will also take around 1000.00 in shocks and probably extended A-arms for another 700.00 to even get the handling comparable to a stock 400ex. And it is still going to weigh more than the 400ex. Not to mention the mods available for the 400. I watch Warriors compete every other weekend at the track where my son is racing and it takes a lot more than a piston, cam, and pipe for a Warrior to outrun a 400EX. Why spend 5000.00 on a Warrior when you can buy a used 400EX for 3200.00 to 3600.00 and have more quad right from the get go. And then spend money on modding the 400ex out.
