lt-f250 neutral sensor problem
Old May 20, 2003 | 08:41 PM
dougvan's Avatar
Default lt-f250 neutral sensor problem
My 2001 lt-f250 has sporadically been unable to start because it doesn't think it's in neutral -- e.g. the green "N" light won't light up (and yes, I am in neutral -- I can push the atv forward). Another symptom of this problem is the the red "R" light won't come on if I put the atv into reverse. I have been unable to manually start the atv when this condition arises (which I can when the green "N" light is lit). This leads me to believe that I may not be getting a spark, either. Although I've also had the "N" and "R" lights fail even when the atv is running.
Anyways, this condition has been occuring more frequently and I need to do something about it. Does anyone have any ideas before I take it into the shop?
Thanks,
Doug
Old May 21, 2003 | 03:55 AM
Zukimoto's Avatar
Your reverse light switch or neutral switch may be going out. You won't get spark if that's happening.
A factory service manual could help you diagnose and repair this problem if you're comfortable doing your own work.
John
greg74
Sep 10, 2019 03:03 PM
JoAnnS
Jul 23, 2015 02:18 PM
ltrmc02
Jul 22, 2015 04:50 AM
tporath
Jul 11, 2015 12:31 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
