27" tires for vinson 5 spd
Originally posted by: Woody500
The C-Series are a 1" wider than the stockers,therefore you have more offset about 3/4" I believe.Not sure if 26's will work or not?I guess it depends on how wide of a 26 you go with.Not sure what will work on the Eiger,I've never had any dealings with this bike!
gmag, I broke both my cv's going forward in deep snow (trail riding). I also have a problem with the shifter missing shifts on speed shifts or under load. The 589's I have do rub a little but only under full compresion, or very tight low speed turns, rubs so little I don't feel it, but you can hear it. Any one else?
warnerave, i ran in the snow all winter plowing and ice fishing and never blew an axel but when i was back dragging dirt with my plow and pushing brush i blew two of them. by the way if you want to perk the vinson up jet it, and put a hmf pipe on it with a decent air cleaner. i did mine and can't believe the low end power i gained. it seems to have lost a little top ed but i am going to contact the dealer and ask him if this is normal. i think i am also dropping down a size on tires to 26".
Sep 30, 2015 01:37 AM
