Z400 clutch lever replacement
Old Jun 2, 2003 | 07:42 PM
jt's Avatar
jt
Default Z400 clutch lever replacement
i took the parking brake off my z400 and now i'm stuck with this big *** bracket that part of my clutch lever brackets. can anyone tell me a good source for finding the lever assembly i need. also there is sort of rubber square piece sticking out of the assembly with a wire leading from my start button it appears. if not for that i'd just replace the lever and ride on. is that what causes me to pull the clutch in when i crank it? where can i stick that thing where it's nice and neat? i really need some help guys i've got a big riding trip on saturday and my bikes in a few pieces [img]i/expressions/face-icon-small-sad.gif[/img] thanx
Old Jun 2, 2003 | 07:52 PM
jcsact's Avatar
I modified and painted my stock lever. Stock Lever Modified Take a look at some of the other pics too.
Old Jun 12, 2003 | 09:40 AM
quadmanz400's Avatar
you can use any aftermarket clutch lever but you might have to use the adjustment on the cable itself (its about a foot from the end of the cable close to the handle bar clamps) as for the two wires you can just cut them and splice them together its just a hassle for me its a lot easier to start if you kill it during a race or trail riding. I put the magura hydraulic clutch on mine and love it. I'll never own a cable clutch again!
Old Jun 13, 2003 | 11:39 AM
RaptorOwner's Avatar
jcsact - Where did you get the black rubber piece that replaced your oem one? I have been thinking of modifying my Raptor clutch handle cuz I took the e brake off too. Looks kinda funky with it all hanging out there.
Old Jun 13, 2003 | 11:51 AM
KGB's Avatar
KGB
Just get the RTC lever. It looks so good, and the new one has a quick adjuster. Plus later you can match your brake lever to it.
Old Jun 13, 2003 | 01:47 PM
jcsact's Avatar
I went to the stealership and had them look around to see if there was anything that might work. The hole the cable went threw was to small. It kind of tappered down so I trimmed it till the cable would fit threw. I have the part number for the one I used at home. I know it was a kawasaki part. Let me know if you need it.
Old Jun 13, 2003 | 01:58 PM
Sure - If you can PM me with it that will be good.
THanks
Old Jun 13, 2003 | 02:32 PM
Thanks - Just ordered two of them, it looks like it will fit both the Raptor and the Z. I really didnt want to get rid of the saftey switch.
Old Jun 20, 2003 | 05:20 PM
Took my raptor Clutch handle down to my brothers shop and cut off the top layer with all the e brake stuff, buffed it and placed those rubber gaurds on and it looks sweet. Thanks for sharing your information. Now I am going to do the same thing to the Z.
Old Jun 20, 2003 | 05:38 PM
jcsact's Avatar
No problem glad I could help.
ghost civic
Jan 15, 2020 07:43 AM
Jul 15, 2015 02:07 AM
clsharky
Jul 13, 2015 02:07 PM
coolguy420
Jul 10, 2015 01:17 AM
yambam13
Jul 4, 2015 01:49 PM
