Z400 water pump leak
[img]i/expressions/face-icon-small-frown.gif[/img]
My Z 400 has a leak coming from the joint between the water pump and the crankcase. I tried to remove the pump to replace the O ring seal but the pump wont come off with all bolts removed, I suspect the drive gear is too large to fit through the mounting apature. Has ayone had to remove a water pump from this ATV yet? If so please advise if I need to remove the right side crankcase cove to remove the water pump. If that is the case, what a pain in the butt for such a small job!
Many thanks,
DJM
Many thanks,
DJM
Jul 15, 2015 02:07 AM
