LT250R Break In Recomondations
Old Jun 7, 2003 | 05:09 PM
Jmoney's Avatar
Default LT250R Break In Recomondations
Just installed the motor into the frame of my 88lt250r.what kind of break in procedures do you recomond , oil mixture etc.
Its an 88lt250r, new top end .10over, new crank shaft and rod, main bearings seals,
just checking to see what the norm is, thanks for the help
Old Jun 8, 2003 | 03:42 AM
scosho's Avatar
Just had similar work done to my LT. The mechanic told me to ride no higher than about half throttle for the 3/4 tank of fuel I have in it, then the rings and bore should match and its okay to let it rip. I can't wait to feel the combination of Uni air filter, FMF pipe, rebuilt top end wide open! I'm also running a little richer oil mix in my fuel @ first. Good luck, keep us posted.
Old Jun 8, 2003 | 03:52 AM
HUEDOGG's Avatar
i say you should wait until about 4th tank and when you fill up for 5th tank your good to let that zuki RRIIIPPPP. Iwaited until i got to the beginning of the 5TH im serious on that because some people say you dont need to wait but they were"misinformed"and they probably didn't let the rings seat properly.
Levi Enstad
Sep 26, 2015 08:00 AM
nastyblaster100
Sep 13, 2015 01:19 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Halffast17
Sep 11, 2015 02:30 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
