230 quadsport
Old May 12, 2000 | 01:14 PM
20warrior00's Avatar
I need help!! I have an '86 230 quadsport that keeps throwing the chain. I have replaced the chain and both sprockets and it still throws the chain. As any 230 owners knows that can be quite expensive if it keeps breaking the magneto cover. So my question is, what should I look for in trying to fix my problem. Any suggestions would be greatly appreciated.
Old May 12, 2000 | 02:16 PM
92LT's Avatar
Quadsports had problems with the swingarm bearings going bad. Make sure there is no play in the swingarm bearings and also the rear axle bearings.
Old May 12, 2000 | 03:38 PM
Y2K300EX's Avatar
Yeah, those are the first things to check.
Y2K300EX's Avatar
Old May 12, 2000 | 08:20 PM
Suzuki102's Avatar
My uncle had the same problem... but with his 250cc 3wheeler, what happened was that the motor shifted on the frame and the front sprockets were not alligned with the back one, so therefor the chain would jump the sprockets.
230cc QuadSport
300cc KingQuad
hoping to get a 500cc QuadRunner this fall.
Old May 14, 2000 | 02:44 AM
CANADA's Avatar
i have a 230 & i replaced 2 magneto covers for it
& then i replaced the chain sprockets& axle bearings,( i need swingarm bearings) & since then the chain never came off! BUT make sure you keep your chain tight
Old May 14, 2000 | 10:38 PM
suzukiboom's Avatar
I have a 230 and it's pretty fast(it beats 250x's and 300ex's)and i broke 3 magneto cover and at $75
that's not cheap,try replacing the swing arm bearing and the axle bearing and tighting the chain often,i replaced that i mine and it hasen't thrown a chain since.
Valder
Nov 28, 2020 07:38 AM
fd24
Jan 16, 2019 08:59 AM
Nekolai1
Aug 25, 2015 10:04 PM
NatePerz
Jul 27, 2015 03:27 AM
rotaxtwin
Jul 1, 2015 07:15 PM
