z400 sprocket change
Old Jun 24, 2003 | 12:16 AM
jt's Avatar
jt
Default z400 sprocket change
ok now that i've got my yoshi and prodesign filter, i need to make some more changes..like everyone says, you go up a tooth and lose the bottom end, go down a tooth and lose the top end. well i think i've got enough low end now to go up a tooth or 2...i can't believe how much bottom end torque and power this thing has now..i'd just like to spread it out a little bit....can you guys please tell me what the best sprocket combination is from stock? i want to retain some most of the bottom but gain some on top
Old Jun 24, 2003 | 09:11 AM
Toyguy's Avatar
Stock, the Z has a 14/40 sprocket combo. If you want to add a little top end then change the rear sprocket to a 39, if you want drastic top end change the front sprocket to a 15. The front sprocket is a bigger jump than the back. For every tooth up front is about 2.5 teeth in the rear. Hope this helps you.
Chris
NewGuy2481
Oct 6, 2015 05:54 AM
Canamaniac!
Sep 15, 2015 06:19 PM
bigbear350quad
Sep 11, 2015 12:40 PM
1ArmBandit
Sep 8, 2015 08:59 PM
Jason Campbell
Sep 7, 2015 02:25 PM
