Gasket problems
Old Jul 2, 2003 | 01:04 PM
QRCRman15's Avatar
Default Gasket problems
I was wondering about how to check if you have blown a base gasket. Are there any ways?
Old Jul 2, 2003 | 02:09 PM
greenbud's Avatar
hello!
well you could start the bike and listen to the idle... then spary some carb cleaner at the base.
if it's sucking air you will be able to tell...
also i have heard that this is a commen problem.... i don't know why.. i haven't had that happen to me. (YET)
hope this helps.....
Old Jul 2, 2003 | 02:27 PM
QRCRman15's Avatar
you sure about the carb cleaner its ok for that to go in the cylinder?
Old Jul 2, 2003 | 02:35 PM
greenbud's Avatar
as i said i haven't had to do this yet... but i'm almost positive thats what you would use..
you don't have to soak it down... frist place i would check is under the reed cage... start the bike bring it to an idle.. then just spay some (not a lot) find the leak and turn the bike off ....
Old Jul 2, 2003 | 02:54 PM
QRCRman15's Avatar
what about bubbly water
Old Jul 2, 2003 | 03:06 PM
greenbud's Avatar
NO!!!!!!!!!!!!! besides even if you could use bubbly water (but you don't) it's not like a tire.
your motor will not bubble like a tire..... if you have an air leak it will suck the air into the motor
and cause it to rev above normal. when you spray the carb cleaner on the leak it should idle down... places to check: under the reed cage, the boot from the carb to the reeds, the head gasket and the crank seals. one is easy (the flywheel side) take that cover off and try to get some carb cleaner behind the flywheel (while the bike is running)
here's something you could do.. call a local shop and ask them how to check for an air leak.
i'm 90% sure they will tell you the same as i have.. and if they don't call another shop..
what ever you do don' use water....
hope this helps
Old Jul 2, 2003 | 08:55 PM
Slacker1bob's Avatar
Actually that is backwards.
First of all use starting fluid, it will give better results, second, when you spray, the motor will idle up, not down, because the spray acts as a little extra boost of fuel. I don't think carb cleaner is bad, but starting fluid is what I have used, and it just seems like the better choice.
Old Jul 3, 2003 | 08:35 AM
greenbud's Avatar
whats up
ya like i said i haven't had to do this yet.. thanks slacker1bob! thats why i told him to call a shop.. and they would tell him what to do. but i do know one thing... no bubbly water!!!
see now i know (thank to slacker1bob) what to do and listen for when i have to do it..
thanks
greg74
Sep 10, 2019 03:03 PM
SDR-II
Sep 29, 2015 01:06 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
Coryco
Jul 6, 2015 07:30 PM
