What Gearing on Quadzilla
Old Jul 3, 2003 | 06:54 PM
RodSmith32's Avatar
Default What Gearing on Quadzilla
What gearing are you running on your built quadzilla? I would like to know what you are using for both paddle and dirt tires. Thanks for your input. BTW I am running a stage IV engine with hi comp.
Old Jul 3, 2003 | 07:46 PM
theTICK's Avatar
Hey Rod
I run on small in the front for beter quickness because it is hauling a BIG load on it's back!!!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 4, 2003 | 12:59 PM
1SickPred's Avatar
when I had mine I went down 1 tooth from stock in the front and had 22" tires. I had the cylinder ported high comp. a pipe and had a khein carb that was bored. I rode it on the streets and in the woods. hope this helps.
Old Jul 4, 2003 | 03:52 PM
RodSmith32's Avatar
What was the stock gearing on the Zilla? Tick how does your LRD zilla run, what kind of pipe do you have on there?
Thanks Rod
Old Jul 4, 2003 | 05:14 PM
donzilla's Avatar
87 stock gearing was 13 , 42 . 88-90 was 13 , 40 . for the trails and stuuf i run a 13 -42 with 20 inch tires . for dirt drags and sand drags i run a 14 - 42 with 22 inch tires . i rearly run a 12 tooth because of the low end of the bike . 1st gear is about useless with 20 inch tires .
Old Jul 5, 2003 | 01:38 AM
jmg87lt500's Avatar
i run 14 /38 with 18 inch tires and it seems to work good
Old Jul 5, 2003 | 07:25 PM
zoo's Avatar
zoo
I run 14/42 w/22 inch tires in dirt, trail, and race. In sand I 12/42 w/22 inch paddles, the sand just sucks the power if I use a larger frnt gear
Old Jul 6, 2003 | 09:28 PM
Louh's Avatar
14/42 with 10 paddle hauler(22") leave in second when racing
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
