dose any one have stock specs for a 87 lt500r
Old Jul 7, 2003 | 09:38 PM
scooby23taylor's Avatar
Default dose any one have stock specs for a 87 lt500r
dose any one have stock specs for a 87 lt500r. what i mean by specs is hp, tourq, weel base, tires, exc...
Old Jul 7, 2003 | 11:04 PM
LT250RSuperstar's Avatar
I the specs for the Quadzilla but not specifically for the '87.
Here are the specs I have:
Suzuki Motor Corporation released the following specifications for the LT500R. As of this writing, only the wheelbase is confirmed slightly different across model years.
Displacement: 499.5cc
Bore & Stroke: 86mm & 86mm
Compression: 7.2:1 (corrected 6.3:1)
Carburetor: Mikuni TM38SS, flat slide
Lubrication: Oil premix
Ignition: Suzuki PEI (CDI-type), 4° @ 1,000rpm, 12° @9,000rpm
Starter: Primary kick
Transmission: 5-speed, manual clutch, no reverse
Transmission ratios: primary 2.142 (60/28), 5th 0.909 (20/22), 4th 1.100 (22/20), 3rd 1.333 (24/18), 2nd 1.733 (26/15), 1st 2.416 (29/12), final 3.076 (40/13)
Final Drive: #520 chain, O-ring sealed
Overall Length: 1,920mm (75.6")
Overall Width: 1,205mm (47.4")
Overall Height: 1,110mm (43.7")
Seat Height: 790mm (31.1")
Wheelbase: 1,345mm (53.0")
Ground Clearance: 110mm (4.3"), at rear axle
Dry Weight: 178kg (392 lbs)
Fuel Tank Capacity: 13 liter (3.4 gal) including reserve
Front Wheels: AT21x7-10 fully corded tires on aluminum rims, using 4 on 166mm bolt pattern
Rear Wheels: AT20x11-10 fully corded tires on aluminum rims, using 5 on 130mm bolt pattern
Brakes: triple hydraulic disk, single piston caliper designs
Front Suspension Travel: 9.1", double A-arm with adjustable preload and 4-way rebound damping
Rear Suspension Travel: 9.1", "Full Floater" linkage, adjustable preload, 21-way compression, and 26-way rebound (SLR 2.11:1)
Caster: 10°
Camber:
Trail: 42mm (1.7")
Toe-in: 11-19mm (0.4-0.7")
Turning Radius: 2.8m (9.2')
Turning angles: 32° inside, 25° outside (±3°)
Fuel: 85 octane pump fuel (R+M)/2
Warranty: three-month
I think this is what you looking for.
later
Superstar
Old Dec 9, 2003 | 07:52 PM
v8vega350's Avatar
i noticed that there is a timming spec for 9000 rpm but people have told me it dont rev that high whats with that
Pehter
Oct 3, 2024 11:00 PM
dannytas
Sep 26, 2017 06:31 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
raman8tor
Sep 20, 2015 07:35 AM
