BROKEN BOLT ON SHOCK MOUNT, NEED HELP
go to your local hardware store and get a backout bit (not sure what they're called) tell the hardware folks the problem, they;ll know what you need. then basically all you do is drill a small hole into the bolt, insert the backout bit and screw it out. good luck!
Cantbuytime
Aug 17, 2015 06:33 PM
