who knows the most about a 250 quadracer
Old Aug 4, 2003 | 12:39 AM
DollarBillz's Avatar
Default who knows the most about a 250 quadracer
im a four strock guy but i could not pass this up i bought a 86 lt 250 quadracer friday it has elka shocks skid plates fmf pipe mayer plastic for only 800 bucks and it runs i just want to overhaul the motor to make sure everything is okay in the bottom before i give it to my wife
Old Aug 4, 2003 | 02:40 AM
come on im looking for someone that has rebuilt one and what are some good things to do to it
Old Aug 4, 2003 | 12:06 PM
Slacker1bob's Avatar
Well, if you are going to totally overhaul it, od the obvious new bearings and seals. Maybe put in a Barnet clutch kit, have the cylinder and head ported and polished. Put good reeds in it. Wiseco piston. Thats about it. Unless you want to spend some money for a big bore kit or something.
Old Aug 4, 2003 | 12:12 PM
i wish i would have talk to the owner of the bike to find out what he has done but i bought it at a yamaha store do these bikes have problems with crank bearings
Old Aug 4, 2003 | 02:01 PM
sam250's Avatar
I've had my '86 racer since '88. Never even did the top end till about a year ago when my crank seals went. My old main bearings were pretty bad but I rode it back to the truck for about 10 minutes with 2-stroke oil in the tranny 'cause it lost all the oil through the crank seals.
The guy who rebuilt my engine has been building 2 strokes for 20 years. He recommended that I don't port the cylinder 'cause the increase in power would not justify the decreased reliability. Since the early racers don't have a powervalve or external reed cage, there's only so much additional power that can be created with engine mods. He also recommended against installing fiber reeds 'cause you gotta pull the cylinder off the bottom end to replace them.
Congratulations on the deal. The shocks, pipe and skid cost more the 800.
Old Aug 4, 2003 | 02:20 PM
Yeah, but if you are going to have the motor apart anyways, that would be the time to put reeds in. I had my quad mildly ported, and it is just as reliable as when it was stock. I would recommend some porting and polishing so it can open up a bit and breath. as usual dont go nuts, but it really helps to at least clean up all the casting marks. Shave about .010 or .020 off the head. It is enough to gain some power, but not too much to wory about blowing a gasket. and besure to use Suzuki gaskets because I tried the cheaper route and got burned.
Old Aug 4, 2003 | 03:53 PM
it runs good right now but it sounds like it may have a bad bearing on the crank im not trying to make it fast my 4 strock takes care of that i want this bike to run perfect this bike needs to start easy it will be for my wife
Old Aug 5, 2003 | 02:38 AM
Ellison723's Avatar
I have seen anything you can think happen to Lts. Dont get it ported the 86 is just a ported 85. Any bigger exhaust port it will trash the motor pretty quick. No support for piston. Ive rode ported 86s 85s , it aint worth the power increase in those. Get somebody to split it check clearence everywhere get a rod kit, cause that one, if its stock is probobly about shot. Throw a new clutch in also.
Halffast17
Sep 11, 2015 02:30 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
jfboy
Nov 8, 2000 07:06 AM
max250
Aug 8, 2000 09:58 PM
