13 tooth sprocket
Old Aug 11, 2003 | 12:21 AM
1Fast03z's Avatar
Default 13 tooth sprocket
ok i got a z400 i just ordered a 13 tooth front sprocket do i need a new chain and what is the stock chain?? ive heard somethin about a 520 chain with the 13 tooth sprocket some one help me out here
Old Aug 11, 2003 | 12:24 AM
Slacker1bob's Avatar
What is the stock sprocket.
IF it is only one tooth difference, you should be able to just adjust the chain
Old Aug 11, 2003 | 12:33 AM
1Fast03z's Avatar
ok bare with me im not a chain pro the stock is 14 and im gettin 13 it says it will fit but they lie alot it may fit but like crap
Old Aug 11, 2003 | 01:21 AM
Should be enough adjustment to make it work. I am surprised you are going a tooth down, doesn't the z400 already put out a ton of low end torque
Old Aug 11, 2003 | 01:39 AM
1Fast03z's Avatar
with the pipe yeah but ive heard its one hell of a mod for 7 dollars
Old Aug 11, 2003 | 02:30 AM
For $7 its a good experiment, but chances are you will find that 1st gear becomes too lower and useless. But hey, if it does what you want it to do, then its all good.
Old Aug 11, 2003 | 04:48 AM
SRK399's Avatar
I have a 13t sprocket on my Z400. Stock is 14. It makes one hell of a difference. Its so much better, youll love it. All you need to do it adjust the chain, a new one is not needed.
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
