zilla with keihin carb ????
Old Aug 19, 2003 | 02:39 PM
stormnorm's Avatar
Default zilla with keihin carb ????
I need info from anyone with a zilla with a 39mm keihin PJ carb. Tell me your slow jet size and air screw setting. I've been trying to keep an air screw adjmnt of between 1 and 2 turns but I think that this only applies to mikunis. I have presently a 58 slow with maybe 3/4 turn out on the air screw and still runs rich!!! Please help[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 20, 2003 | 10:16 AM
stormnorm's Avatar
Gee Storm, it doesn't look like anyone knows what there carb is jetted at!![img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Aug 20, 2003 | 02:13 PM
Semms40oz's Avatar
a 58 pilot? I'm running a 38mm keihin with a 62 pilot and i'm not running rich. This is on a lt250r at 700' elevation.
Old Aug 20, 2003 | 02:33 PM
stormnorm's Avatar
Geez I can't figure it out...it runs too rich at idle and low RPM!!!!!! The CR500 bike has the same carb and it runs a 55 slow in stock form, so I figure mine should be relatively close?
Old Aug 20, 2003 | 02:55 PM
Semms40oz's Avatar
I think you need to go larger on the pilot. here is a thread where another lt250r dialed in his jetting and he is running a 65 pilot click
This info isn't for the zilla but out of curiousity how do you know you are running rich? I thought mine was running rich with a 55 pilot but it turned out that it was lean
Old Aug 20, 2003 | 04:56 PM
stormnorm's Avatar
It'll start to smoke if I put put around for too long with my kid on the bike or if idling too long! It will bubble bubble bubble when I open her up to WOT and clears up after a couple of high speed runs. It's not burning trany oil or antifreeze. I had gone up on the slow jet to 68 with worst results. Defenately runs much better with a 58 jet in there but still a bit rich. I have a 55 jet on order. I'll try that next!
Old Aug 21, 2003 | 11:38 PM
capecodder's Avatar
so what is a good carb to get . i am running a stock one with jet changes, i would like more power. of course,,, lol i see mikuni 39mm 0r 40 for $160...
Old Aug 23, 2003 | 12:10 AM
TomZilla's Avatar
Hello, you might check out the duncan racing website here there's an article on jetting a keihin carb. For what it's worth I am going to be putting a 39pwk on mine after I get the top end back on and trinity told me to start with a 60 pilot.
Good Luck
Old Aug 24, 2003 | 11:29 PM
capecodder's Avatar
i need to know whaty carb would be good to get now that im over bored and have a good pipe
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
coolguy420
Jul 10, 2015 01:17 AM
